https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> offset in Monte Carlo simulations https://designers-guide.org/forum/YaBB.pl?num=1338104014 Message started by Ajay on May 27th, 2012, 12:33am |
Title: offset in Monte Carlo simulations Post by Ajay on May 27th, 2012, 12:33am I had run a Monte Carlo simulation for determining the offset of an amplifier with 500 trials. At one of the trial, the offset was maximum. * In CADENCE , how do I find the 'trial number' where the offset was maximum ? * I would like to do a temperature sweep at the Monte Carlo trial where the offset is maximum. Can someone give suggestions for doing the above in Cadence ? |
