https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Jitter Measurement using eye diagram in cadence https://designers-guide.org/forum/YaBB.pl?num=1338246041 Message started by nadroit on May 28th, 2012, 4:00pm |
Title: Jitter Measurement using eye diagram in cadence Post by nadroit on May 28th, 2012, 4:00pm Hello All, I used Ken's Verilog-A code of VCO with jitter. I set jitter input to 10ps and ran transient simulation. Then I plotted eye diagram of output but I don't know hoe to measure jitter from eye diagram in cadence. Please help. I am using IC5.1 Thanks |
Title: Re: Jitter Measurement using eye diagram in cadence Post by ywguo on Jun 13th, 2012, 6:31pm Hi nadroit, If you cannot access cadence online help, generate eye diagram of the VCO output and measure it with delta cursors. :) If you can access cadence online help, please have a look at solution # 11395772, 11018920, and 11564054. Or have a look at the following link. http://www.designers-guide.org/Forum/YaBB.pl?num=1293197122/0#0 BTW, I am not sure whether the solution in the above 3 solutions are all compatible with your product version, IC51. Best Regards, Yawei |
