https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> inverter delay https://designers-guide.org/forum/YaBB.pl?num=1338799971 Message started by raja.cedt on Jun 4th, 2012, 12:52am |
Title: inverter delay Post by raja.cedt on Jun 4th, 2012, 12:52am hello all, can any one please tel me how inverter delay can controlled.... Basically delay is charging rate, so either I has to increase current or capacitance has to decrease. 1. So in-principle increasing size should n't change the delay (neglect parasitic cap) due to increase in I and Cap simultaneously. is this correct??? 2. What about current steering...this will increase current without increasing the cap, so what is the bottle neck here???? 3. Is there any way to get fine delay in a given technology? Thanks, raj. Thanks, Raj. |
Title: Re: inverter delay Post by boe on Jun 5th, 2012, 10:48am Hi Raj, raja.cedt wrote on Jun 4th, 2012, 12:52am:
- B O E |
Title: Re: inverter delay Post by aaron_do on Jun 5th, 2012, 4:50pm Hi, if you want more delay, can't you just increase the gate length? Aaron |
Title: Re: inverter delay Post by loose-electron on Jun 5th, 2012, 8:48pm what are you trying to do? create a variable delay? Or what? |
Title: Re: inverter delay Post by Lex on Jun 6th, 2012, 1:13am You want a finely controlled delay. I'd say you'd need go digital to do so. Some controllable logic in which you can program the delay (e.g. via a set of flipflops) combined with an accurate clock is very process independent as well. |
Title: Re: inverter delay Post by RobG on Jun 6th, 2012, 7:22am Your belief that delay will be constant for the inverter sounds reasonable only if you don't include loading. Power supply and the slope of the driving voltage also affect timing. You obviously need bigger devices to drive a bigger load. A long time ago I found that the best speed/power tradeoff was with driving inverter 1/3 the size of the load gate. Not sure if that is still true. If you limit the swing like is done with PECL you can get faster response at the expense of having static current. |
Title: Re: inverter delay Post by rfcooltools.com on Jun 7th, 2012, 10:59am Lowering or raising the supply will change the delay. http://rfcooltools.com |
Title: Re: inverter delay Post by ywguo on Jun 8th, 2012, 7:02am Hi Raj, What's your purpose of controlling the delay of inverters? You asked the way to get fine delay. How fine? <10ps or ?? Even on-chip microstrip lines are adopted to get very fine delay, like 10ps/step. Please refer the following paper. Quote:
Yawei |
