https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> OIP3 substitution method https://designers-guide.org/forum/YaBB.pl?num=1339072851 Message started by jae on Jun 7th, 2012, 5:40am |
Title: OIP3 substitution method Post by jae on Jun 7th, 2012, 5:40am I'm trying to figure out how to back calculate the OIP3 of an amplifier by measuring it in a system with a mixer and then measuring the mixer itself. I do see a difference (degradation) in the intermod products when I measure the mixer by itself vs. inserting the amp so I know the system IP3 is being effected by the amp. I measure the mixer at the same power level input that the amp will put into it when inserted so I keep the level into the mixer the same. Does anyone have any idea how to back calculate this? |
