https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> MESFET, GaAs, or pHEMT process option https://designers-guide.org/forum/YaBB.pl?num=1339133556 Message started by apprentice on Jun 7th, 2012, 10:32pm |
Title: MESFET, GaAs, or pHEMT process option Post by apprentice on Jun 7th, 2012, 10:32pm hi all, Could you suggest some good process options for MESFET, GaAs, or pHEMT ? Any comment on the state of art of them? thanks |
Title: Re: MESFET, GaAs, or pHEMT process option Post by loose-electron on Jun 10th, 2012, 1:19pm It depends on what you are trying to do. So, care to define the question a bit better? |
Title: Re: MESFET, GaAs, or pHEMT process option Post by apprentice on Jun 21st, 2012, 2:02pm it is for broadband power amplifier design. |
Title: Re: MESFET, GaAs, or pHEMT process option Post by loose-electron on Jun 25th, 2012, 6:20am GaAs is probably the most mature technology. RF PA's have been done there for many years. Figure out your power and voltage requirements first. Then go look at the capabilities of the particular process. Breakdown voltages and similar come into play. |
Title: Re: MESFET, GaAs, or pHEMT process option Post by apprentice on Jul 3rd, 2012, 9:52am thanks. will figure out prerequisites. |
