https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> about Mixer Simulation (raise time of LO) https://designers-guide.org/forum/YaBB.pl?num=1339436530 Message started by Muhammed on Jun 11th, 2012, 10:42am |
Title: about Mixer Simulation (raise time of LO) Post by Muhammed on Jun 11th, 2012, 10:42am How much raise and fall time should i put when i make simulation of Mixer .. i am using rail to rail square pulse ??? |
Title: Re: about Mixer Simulation (raise time of LO) Post by RFICDUDE on Jun 11th, 2012, 4:34pm Well ... What really matters is the rise/fall time of the buffers that will actually drive the capacitive load of the mixers switches. It is not a good idea to drive the mixers with ideal voltage waveforms with finite rise/fall times because ultimately the rise/fall times are limited by the driver slew rate and parasitic capacitance. |
Title: Re: about Mixer Simulation (raise time of LO) Post by Muhammed on Jun 11th, 2012, 5:05pm ok .. so How much rise/fall time should I put when I simulate the mixer itself without buffers ??? I am using tsmc13rf tech file in cadence .. is there any data i can get about this ?? |
Title: Re: about Mixer Simulation (raise time of LO) Post by RFICDUDE on Jun 11th, 2012, 7:13pm What are you trying to emulate by setting the rise/fall time? An ideal voltage source will drive the gates without any consideration for the capacitance load of the gates; therefore, the rise/fall time of the voltage source (I assume you are driving the gates with a voltage source) is meaningless. You need a buffer; otherwise, what are you trying to model by using the rise/fall time? |
Title: Re: about Mixer Simulation (raise time of LO) Post by Muhammed on Jun 12th, 2012, 12:52am I want to see the effect of rise/fall time of LO on mixing action .. so i want to roughly rise/fall time to LO voltage source . |
Title: Re: about Mixer Simulation (raise time of LO) Post by RFICDUDE on Jun 12th, 2012, 4:02am Ok, then I would sweep the rise/fall time to see the impact on mixer conversion gain/loss, linearity and NF. The maximum rise/fall time should be fast enough for the pulse to transverse from 0 to the supply voltage and back down to 0 for the shortest pulse width you need (i.e. highest LO frequency). |
