https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Problem on SCL Latch in 40nm technology https://designers-guide.org/forum/YaBB.pl?num=1339769463 Message started by Yutao Liu on Jun 15th, 2012, 7:11am |
Title: Problem on SCL Latch in 40nm technology Post by Yutao Liu on Jun 15th, 2012, 7:11am Hello everyone, I am designing a divided-by-2 with SCL latch by 40nm low power technology. The supply voltage of the circuitry is limited to 1.1V, and the threshold voltage of transistor is about 0.6V. As shown in simulation result in figure 2, there is a significant spike in the latch output waveform. In my opinion, the NMOS as tail current source is biased at triode region so that the ripple at node Y is large. The ripple causes incomplete switch of the clock-driven differential pair. As a result, the input differential pair still amplifier input signal even when the clock is supposed to shut them down. My questions are, 1. Is my analysis right? 2. The circuity topology is three NMOS in stack. It is difficult to bias this circuit with the limited supply voltage and large threshold voltage. Can I abandon the tail current source to get an easier bias? It there any suitable topology? 3. Can my circuit be further optimized? It seems useless to adjust parameters in the circuit. Thanks in advanced, Yutao |
Title: Re: Problem on SCL Latch in 40nm technology Post by Yutao Liu on Jun 15th, 2012, 7:14am Figuire2 is shown as following. |
Title: Re: Problem on SCL Latch in 40nm technology Post by loose-electron on Jun 15th, 2012, 9:52am Yutao Liu wrote on Jun 15th, 2012, 7:11am:
Try using a resistor instead of the current source. |
Title: Re: Problem on SCL Latch in 40nm technology Post by Yutao Liu on Jun 16th, 2012, 1:03am Thanks Jerry, I will try your idea. Could you tell me why resistor as tail current source is your option. I think the resistor would display the same characteristic as an NMOS in triode region. The ripple at node Y still exist. Do I miss anything? Best, Yutao |
Title: Re: Problem on SCL Latch in 40nm technology Post by Yutao Liu on Jul 2nd, 2012, 7:44am loose-electron wrote on Jun 15th, 2012, 9:52am:
The spike does exist with resistor, and the amplitude is the same as that with current source. But the swing(Vmax-Vmin) becomes larger. I checked the circuit again and found that there is about 160uA gate leakage current in the clock-driven differential pair. I think this leakage also causes the spike, doesn't it? Thanks, Yutao Liu |
Title: Re: Problem on SCL Latch in 40nm technology Post by Lex on Jul 4th, 2012, 12:38am You say that the threshold is 0.6 V? So why biasing the current source at 535.6 mV? I guess it should be at least 0.7 V? |
Title: Re: Problem on SCL Latch in 40nm technology Post by Yutao Liu on Jul 6th, 2012, 7:46pm Lex wrote on Jul 4th, 2012, 12:38am:
The threshold is 0.6V when the length of FET is 40nm. And the threshold voltage decreases when length increases. In the schematic attached, the length of current source is above 40nm. So its bias voltage is lower than 0.6V. Best, Yutao |
Title: Re: Problem on SCL Latch in 40nm technology Post by Lex on Jul 9th, 2012, 12:59am Okay that makes sense. Did you try optimizing the common mode level of the clock? Are you certain the coupling cap is large enough? Can't see any sizes on the schematic, but I assume you thought about it. |
