Measurements >> Other Measurements >> Temperature measurement
https://designers-guide.org/forum/YaBB.pl?num=1342572231
Message started by mixed_signal on Jul 17th, 2012, 5:43pm
Title: Temperature measurement
Post by mixed_signal on Jul 17th, 2012, 5:43pm
Hi,
I need to test a circuit based temperature sensor with the following specs. Can someone suggest a good platinum RTD (with vendor)?
Range: -20 to 30c
Accurac +-0.1C
resolution 0.01c
Title: Re: Temperature measurement
Post by ywguo on Mar 24th, 2014, 2:57am
Hi,
What did you do to keep the temperature of the circuit from deviating from that of the platinum RTD?
Best Regards,
Yawei
