https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> how to characterize gamma of mosfet https://designers-guide.org/forum/YaBB.pl?num=1342890107 Message started by avlsi on Jul 21st, 2012, 10:01am |
Title: how to characterize gamma of mosfet Post by avlsi on Jul 21st, 2012, 10:01am Hi all, We all know that there is factor of gamma in output current noise of the mosfet. In eldo simulator, the output noise units are v/√HZ. I would like to know how can i get output noise as A/√HZ ? Thanks in advance |
Title: Re: how to characterize gamma of mosfet Post by Geoffrey_Coram on Jul 23rd, 2012, 6:35am Output noise in a spice(-like) simulator is generally computed as the noise voltage at a particular node, hence the units of V/rt Hz. If you want A/rt Hz, then you need to have a simulator that supports current probes for noise analysis. Check the Eldo manual; I don't know if it does. And you also need a circuit architecture for which the noise current is relevant: if you haven't put on an appropriate load, you circuit won't be supplying current and you won't be able to measure the noise of a non-existent current. |
Title: Re: how to characterize gamma of mosfet Post by avlsi on Jul 23rd, 2012, 7:04am Geoffrey_Coram, I have tried looking for it but could not really find anything. I am not putting any load on top the mosfet. But I am putting an ideal voltage source to set VDS> VGS-VTH. And then sensing the current using CCVS at drain of mosfet and I anticipate the output of CCVS is actually the current noise of mosfet with gain 1. |
Title: Re: how to characterize gamma of mosfet Post by Geoffrey_Coram on Jul 23rd, 2012, 8:44am Yes, that should work. The CCVS does the conversion of A to V, so you can just read the output noise as being in A/rt Hz instead of V/rt Hz. |
