https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Question about output current in VerilogAMS https://designers-guide.org/forum/YaBB.pl?num=1343192269 Message started by urian on Jul 24th, 2012, 9:57pm |
Title: Question about output current in VerilogAMS Post by urian on Jul 24th, 2012, 9:57pm Hi,there I have written a module in AMS, which output a current corresponding with the input binary code as follows: Code:
When compiling the module, it gives a error message which shows that "I(Iout) <+ iout*I" has error with "illegal expression primary". I dont know why and how to fix it, any suggestion will be appreciated. Regards urian |
Title: Re: Question about output current in VerilogAMS Post by ywguo on Jul 25th, 2012, 1:57am Your module has not any module name. Please do NOT define parameter I because this is an access function for electrical node. Then the error message "illegal primary expression" disappears. Best Regards, Yawei |
Title: Re: Question about output current in VerilogAMS Post by urian on Jul 25th, 2012, 8:45am Thanks Yawei , you are right,the error has been fixed. Then what's the meaning of "illegal primary expression"? Best regards urian |
Title: Re: Question about output current in VerilogAMS Post by ywguo on Jul 25th, 2012, 7:47pm Hi urian, In section 7.3.6.3, VerilogAMS LRM 2.3.1, it reads that an analog primary (variable, potential, or flow) whose value is .... In section 7.3.6.5, VerilogAMS LRm 2.3.1, it reads that a digital primary (reg, wire, integer, etc.) whose value is .... Obviously variable, potential and flow are primary in analog context, and reg, wire, integer, etc. are primary in analog context. In your module, I is defined as a parameter. It results in illegal primary expression because I is access function of flow in verilogAMS. Best Regards, Yawei |
Title: Re: Question about output current in VerilogAMS Post by urian on Jul 25th, 2012, 9:39pm Thank you,Yawei ,I get it! When I writting the module, I am confusing with the output current and voltage relationship.As in my module,there is only current output, then what about the port voltage?How does the module decide it? When I using the module, I find that it makes the CMOS transistor which tied to it go into triode region.I wonder how to avoid it and accurate define the output relationship between current and voltage? Is it because my module is so simply? Regards urian |
Title: Re: Question about output current in VerilogAMS Post by Geoffrey_Coram on Jul 26th, 2012, 5:35am urian wrote on Jul 25th, 2012, 9:39pm:
From the Spice solver's point of view, you've defined an ideal current source. The module/current source doesn't decide the voltage; the solver applies the current and then tries to solve all the node voltages to satisfy Kirchoff's Current Law. |
Title: Re: Question about output current in VerilogAMS Post by urian on Jul 28th, 2012, 3:49am Hi,Geoffrey_Coram.So my module is just a ideal current source and its port voltage is determined by outside network. And I find another problem.When I use "ground gnd" to declare a ground node and use it in "V(a,gnd)" statement, it said the gnd has not been declared.Is something wrong? Regards urian |
Title: Re: Question about output current in VerilogAMS Post by ywguo on Jul 31st, 2012, 6:45pm Hi urian, Did you declare that gnd is electrical node? In Section 3.6.4, verilog-AMS LRM, Quote:
Title: Re: Question about output current in VerilogAMS Post by urian on Aug 1st, 2012, 8:15am Hi,ywguo, I did not declare the gnd as electrical node. I have seen in the book "THE DESIGNER’S GUIDE TO VERILOG-AMS", there is example code as below: //A simple circuit `include “disciplines.vams” `include “vsrc.vams” `include “resistor.vams” module smpl_ckt; electrical n; ground gnd; vsrc #(.dc(1)) V1(n, gnd); resistor #(.r(1k)) R1(n, gnd); endmodule so I dont know it should be electrical. When refer to LRM, I have fixed this error as you said.Thanks a lot! Regards urian |
Title: Re: Question about output current in VerilogAMS Post by Ken Kundert on Aug 1st, 2012, 10:28am My mistake. Sorry about that. -Ken |
