https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> real number model with Systemverilog https://designers-guide.org/forum/YaBB.pl?num=1343277386 Message started by rampat on Jul 25th, 2012, 9:36pm |
Title: real number model with Systemverilog Post by rampat on Jul 25th, 2012, 9:36pm Hi I am trying to model bias current port using real number model as below output real ibias[8:0]; In my testbench where I am instantiating this module I have defined real ibias[8:0] , but the issue is ncverilog is showing error when I pass this variable as .ibias(ibias[8:0]) error message : Part-select ot indexed part-select cannot be applied to memory [4.2.2(IEEE)]. Does this mean that i can not pass variable bus as port ? Thanks |
