https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> The transfer function of a SC integrator https://designers-guide.org/forum/YaBB.pl?num=1343749997 Message started by eeBismarck on Jul 31st, 2012, 8:53am |
Title: The transfer function of a SC integrator Post by eeBismarck on Jul 31st, 2012, 8:53am Dear everyone, I am just starting to design the SC integrator. The one mentioned in the paper 'REDUCTION OF FINITE-GAIN EFFECT IN SWITCHED-CAPACITOR FILTERS' confused me as shown in the attachment. I use the charge conservation scheme, but the result is different from the eq.1 in the paper. |
Title: Re: The transfer function of a SC integrator Post by buddypoor on Aug 2nd, 2012, 6:31am I don't know how deep you are involved in S/C techniques. Therefore, the following hints: There are three basic types of S/C integrators: 1.) EULER-forward approximation 2.) EULER-backward approximatiuon 3.) BILINEAR approximation. The S/C circuit as shown in the referenced document is a specific development to consider parasitic opamp properties. Which type are you going to design? |
