https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> monte carlo trimmed simulation in adexl (cadence 6) https://designers-guide.org/forum/YaBB.pl?num=1343830577 Message started by tempora123 on Aug 1st, 2012, 7:16am |
Title: monte carlo trimmed simulation in adexl (cadence 6) Post by tempora123 on Aug 1st, 2012, 7:16am Hi, Does anyone know how to setup monte carlo simulation under adexl in such way that: - 1st test bench uses tran smulation to find a trimming code for a particular instance (DUT) - 2nd test bench uses dc temp sweep to run a monte carlo trimmed simulation In both test benches DUT should contain devices with the same mismatch spread on their model parameters. Thanks for your help. |
