https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Integrator Design Problem https://designers-guide.org/forum/YaBB.pl?num=1344921201 Message started by analog_design on Aug 13th, 2012, 10:13pm |
Title: Integrator Design Problem Post by analog_design on Aug 13th, 2012, 10:13pm Hi, I am designing simple integrator. When Reset is going in off state. integration is starting.When Integration is started. There is dip from 2.5 V to 2 V after that integration of injected current is starting. I did not understant why there is dip of 0.5 V. Please, help me to understand phoenomenon. Please, go through an attached simulation waveform. |
Title: Re: Integrator Design Problem Post by AnilReddy on Aug 14th, 2012, 5:46am Hi, Could you please elaborate the question and the diagrams further..? Please show the input also..? thanks Anil Reddy |
Title: Re: Integrator Design Problem Post by loose-electron on Aug 26th, 2012, 1:03pm Without more information? Looks like charge injection from a switch into a small integration capacitance. |
