https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> instantiation inside analog block? https://designers-guide.org/forum/YaBB.pl?num=1345534414 Message started by Go,TB on Aug 21st, 2012, 12:33am |
Title: instantiation inside analog block? Post by Go,TB on Aug 21st, 2012, 12:33am I'm new to Verilog-AMS modeling and need helps to check my code as below. What the main module means to do is just to delay the clock signal to a D-flip-flop, and then the output of the D-flip-flop is delayed as output of the main module. //define D flip-flop module adffp (d, clk, q) ...... ...... endmodule //main ckt module module testx (inx, clk, outx); input inx; voltage inx; input clk; voltage clk; output outx; voltage outx; parameter real vh=1; parameter real vl=0; parameter real td=20n; electrical clkdd; //internal net electrical outdd; //internal net analog begin V(clkdd) <+ absdelay(V(clk), 2*td); //delay clk signal by "2*td" adffp dffpx (inx, clkdd, outdd); //instantiation of adffp module with clkdd and inx V(outx) <+ absdelay(V(outdd), 5*td); //delay outdd by "5*td" and then port it out end endmodule[/color] The simulation is done by HSPICE and it complains that "Syntax error, unsupported syntax or illegal keyword at/before 'dffpx', ..." I wonder if it's legal to instantiate the module "adffp" inside analog behavior block. Is there better way to implement the function? Thanks! |
Title: Re: instantiation inside analog block? Post by boe on Aug 21st, 2012, 2:19am Go,TB, The module instantiation in your code does not comply with the LRM v2.3.1 (http://www.designers-guide.org/VerilogAMS/vams231.pdf), sec. 5.2 (syntax 5-1): Instantiation is not analog. - B O E |
Title: Re: instantiation inside analog block? Post by Go,TB on Aug 21st, 2012, 11:20am Thanks for reply. I checked the document you referred. It is like that I can't instantiate the module inside an analog block since the instantiation itself is not analog behavior. I take the instantiation out of analog block and the code is like: //define D flip-flop module adffp (d, clk, q) ...... ...... endmodule //main ckt module module testx (inx, clk, outx); input inx; voltage inx; input clk; voltage clk; output outx; voltage outx; parameter real vh=1; parameter real vl=0; parameter real td=20n; electrical clkdd; //internal net electrical outdd; //internal net analog begin V(clkdd) <+ absdelay(V(clk), 2*td); //delay clk signal by "2*td" end adffp dffpx (inx, clkdd, outdd); //instantiation of adffp module with clkdd and inx analog begin V(outx) <+ absdelay(V(outdd), 5*td); //delay outdd by "5*td" and then port it out end endmodule This work-around can get the job done somehow. But I noticed a warning like: port 'inx' declared, but not used I can't figure out what's going on over there. Just guess that probably this is not best practice to implement the function. Thanks! |
Title: Re: instantiation inside analog block? Post by boe on Aug 22nd, 2012, 7:13am Go,TB wrote on Aug 21st, 2012, 11:20am:
Quote:
- B O E |
