https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> High Speed Serializer Architecture https://designers-guide.org/forum/YaBB.pl?num=1347284539 Message started by analog_design on Sep 10th, 2012, 5:42am |
Title: High Speed Serializer Architecture Post by analog_design on Sep 10th, 2012, 5:42am Hi, I am just confusing with below attached picture. I have some doubt. This is SerDes architecture. 1. Here How 8b/10b and 16b/20b encoded signal is converted into 8:2 multiplexer ? actually ODD parallel inputs to EVEN parallel outputs 2. Why do we need to generated always ODD and EVEN signal at output of Serializer ? If you have any architecture for 8b/10b encoding then, please, suggest me those pipelin topoloy papers. thank you |
Title: Re: High Speed Serializer Architecture Post by ywguo on Oct 5th, 2012, 2:32am Hi analog_design, 1. Probably that is a typo, 8:2 multiplexer. :) I am not sure because I don't know the details and background for your scheme. 2. It is not necessary to generate ODD and EVEN signal at the output of serialier. A reasonable structure comes from your requirement, like speed, and the availabe process, and so on. Best Regards, Yawei |
Title: Re: High Speed Serializer Architecture Post by carlgrace on Nov 28th, 2012, 9:11am ywguo wrote on Oct 5th, 2012, 2:32am:
Actually I don't think it is a typo. The internal diagram of the 8:2 serialzer will be the same as the 2-1 that is explicitly shown in the figure. Really what it means to say is it is 2 parallel 4:1 serializers where the ODD path is only nibble and the EVEN path is another. You only need the ODD and EVEN signals if you are going to use a DDR scheme. Otherwise you only need one data path after the coding block. |
Title: Re: High Speed Serializer Architecture Post by loose-electron on Jan 16th, 2013, 8:41pm You are running the flip flops at 1/2 the output data rate (they are slower than just simple gates) and then using Muxes to do the last 2:1 combination at the full speed data rate. |
