https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> Parametrized busses in Verilog-A https://designers-guide.org/forum/YaBB.pl?num=1349372461 Message started by radius2 on Oct 4th, 2012, 10:41am |
Title: Parametrized busses in Verilog-A Post by radius2 on Oct 4th, 2012, 10:41am Hi I'm trying to create an instance with a parametrized bus in Verilog-A i. e. when I instantiate it in a schematic in cadence, then there should be a parameter to determine the size of the bus by clicking on the instance and pressing Q. The idea is to avoid creating several instances with the same functionality but with different bus sizes. However, I'm wondering if this is possible. What would happend with the bus pin when the symbol is created? I've come across a few ways that give some clues for example: module adc(out, in, clk); . . parameter integer bits = 8; // resolution (bits) . . output [0:bits-1] out; electrical [0:bits-1] out; This however generated the following error: "Encountered missmatch in size of formal and actual for out, make sure the size of formal and actual match" Another example I found, used the line `define bits 8 before the line module adc(out, in, clk);, instead of defining bits as a parameter. However this doesn't include the possibility to change the bus size when putting the instance in the schematic. So before I discard the idea completely I wanted to ask here if this is possible to do. |
Title: Re: Parametrized busses in Verilog-A Post by boe on Oct 5th, 2012, 5:44am radius2, Verilog-A should allow parameterized bus widths for ports and signals. However, the Cadence Verilog-A implementation does not seem to support this: According to Cadence Verilog-A reference v11.1 (Sept 2011), "parameter-sized ports" are not supported by their implementation. - B O E |
Title: Re: Parametrized busses in Verilog-A Post by radius2 on Oct 5th, 2012, 7:49am Ok good to know. Thanks for your reply. I'll go on creating instances with different number of bits instead. |
Title: Re: Parametrized busses in Verilog-A Post by Frank Wiedmann on Oct 8th, 2012, 1:15am You might want to check if you can adapt the approach using symbol and schematic pcells which was used for the bussetp component for your purposes (see http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11696480). |
