https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> waveform tick marks in Ocean https://designers-guide.org/forum/YaBB.pl?num=1349977553 Message started by danmc on Oct 11th, 2012, 10:45am |
Title: waveform tick marks in Ocean Post by danmc on Oct 11th, 2012, 10:45am Is there a simple way in Ocean to have a tick mark show up at every data point for a plotted waveform? In Analog Design Environment it is easy, (Curves->Options and then check the tick at every point checkbox). I'm striking out with the manuals. Thanks -Dan |
