https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Break feedback loop for PSRR https://designers-guide.org/forum/YaBB.pl?num=1351154931 Message started by casual on Oct 25th, 2012, 12:48am |
Title: Break feedback loop for PSRR Post by casual on Oct 25th, 2012, 12:48am hi When measuring PSRR for a opamp with feedback loop, do I need to break the feedback loop as mandated in gain plot measurement.. the ac source is in the vcc when measuring psrr. i did a two cases, it gives me huge differences. |
Title: Re: Break feedback loop for PSRR Post by buddypoor on Oct 25th, 2012, 1:27am One of the benefits of negative feedback is - among others - the improvement of the PSSR. Thus, of course the loop should remain closed during PSSR determination. |
Title: Re: Break feedback loop for PSRR Post by raja.cedt on Oct 25th, 2012, 5:19am hello Casual, as you said both will be differed by exactly by loopgain. If you break the loop then simply noise will come and appear at output but if you have loop then it will start correcting, hence less PSRR. Thanks, Raj. |
Title: Re: Break feedback loop for PSRR Post by loose-electron on Oct 28th, 2012, 11:03am One other important thing here - mismatched elements. Your PSRR will be very good with everything nicely matched. Progressively worse when you put in expected mismatches. Consider some Monte Carlo type simulations. |
Title: Re: Break feedback loop for PSRR Post by casual on Oct 28th, 2012, 5:48pm yes, i did not break the loop when sim the PSRR. BUT i look at the Jacob Baker book, page 791 figure 24.27, the PSRR test setup with big RC to break the loop. It confused me. is the setup diagram wrong? |
Title: Re: Break feedback loop for PSRR Post by buddypoor on Oct 29th, 2012, 12:00am I don`t know the Baker book but perhaps he wants to demonstrate the improvement in PSSR due to feedback (comparison with/without loop closed)? |
Title: Re: Break feedback loop for PSRR Post by raja.cedt on Oct 29th, 2012, 12:15am hello casual, what buddypoor is saying correct. According to baker book he is trying to show loop gain and open loop PSRR in the same simulation and by dividing both you get closed loop PSRR. Thanks, Raj. |
