Design >> High-Speed I/O Design >> low BW pll loop filter
https://designers-guide.org/forum/YaBB.pl?num=1354559159
Message started by raja.cedt on Dec 3rd, 2012, 10:25am
Title: low BW pll loop filter
Post by raja.cedt on Dec 3rd, 2012, 10:25am
Hello,
While reading a doc from ee times, i came to know that there are few applications which require PLL bw around 10Hz, i wounder how people manage that kind of filters. The only one idea came to my mind when i read this nA charge pump current  and very low resistance. I would like to hear some implementable solution.
Thanks,
Raj.
Title: Re: low BW pll loop filter
Post by smlogan on Apr 11th, 2013, 8:35am
Hi Raj,
Loop bandwidths of this magnitude are usually bulkwave quartz based. In other words, the Kvco is very low (often much less than 100 ppm/V). They are used for highly stable clocks often referred to as Stratum III or better. In some cases, the frequency varying element is non-crystalline, but also possesses an extremely low Kvco.
I hope this helps!
Shawn
Post by raja.cedt on Apr 11th, 2013, 11:39am
hello thanks for the reply. Do you mean filter might be a SAW based and VCO based on crystal oscillator??
Thanks,
raj.
Post by Lex on Apr 12th, 2013, 1:43am
Go digital?
Post by smlogan on Apr 17th, 2013, 1:23pm
Hi Raj,
Sorry for the delayed response...
Yes. A bulkwave quartz based oscillator (VCXO) will have a lower Kvco in general than a quartz surface acoustic wave based oscillator (VCSO). Hence, the latter is most often used in low bandwidth PLL.
Shawn
