https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Do we need a digital filter following a SAR ADC https://designers-guide.org/forum/YaBB.pl?num=1355289372 Message started by zrsh001 on Dec 11th, 2012, 9:16pm |
Title: Do we need a digital filter following a SAR ADC Post by zrsh001 on Dec 11th, 2012, 9:16pm I am a freshman for ADC design. when i use a SAR ADC with sample clock about 2.4 MHz for input signal, whose bandwidth is 100 KHz. We have OSR=12. When finished adc conversion, do we need a digital filter after ADC ? The quantization noise is spread about(0, 1.2MHz) while signal bandwith is only about 100KHz. If we use a digital filter, we can suppress the noise from 100K to 1.2MHz and SNDR will increase a little bit. Is it correct ? |
Title: Re: Do we need a digital filter following a SAR ADC Post by carlgrace on Jan 4th, 2013, 3:38pm Yes if you're oversampling you need a digital filter to gain the benefits of the oversampling. Since you're not doing any noise shaping all you need to do is add up every 12 output data words and divide by 12. |
Title: Re: Do we need a digital filter following a SAR ADC Post by sheldon on Jan 5th, 2013, 9:28pm ZRSH001, Unless you are doing something special with the SAR ADC you do not need a digital filter. For a SAR ADC with oversampling, you need to average the outputs. Store the value of out[n] in a register and add it to the output of the current conversion. out[n]=out[n-1]+ADCOUT When you get done keep the top X number of bits that you need, where X is the number of bits of the ADC. Unlike an oversampling ADC, oversampling of a Nyquist-Rate ADC provides limited improvements in the dynamic range. For example, a 2x oversample rate provides a 3dB improvement, a 4x oversample rate provides a 6dB improvement. Note: this behavior is different than the behavior of a Delta-Sigma ADC. Best Regards, Sheldon |
