https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Digital sizing for RF: PFD https://designers-guide.org/forum/YaBB.pl?num=1356936084 Message started by mixed_signal on Dec 30th, 2012, 10:41pm |
Title: Digital sizing for RF: PFD Post by mixed_signal on Dec 30th, 2012, 10:41pm Hi, I am designing a 2.4Ghz integer N PLL with 1Mhz reference. While sizing inverters for RF is there any special considerations in sizing inverters/gates , I mean PMOS to NMOS ratio etc. I have sized for highest speed i.e. beta=2. Although power consumption is also a concern for me |
Title: Re: Digital sizing for RF: PFD Post by raja.cedt on Dec 31st, 2012, 1:02am hello, though it is RF application, pfd will work as digital block. Make sure that Inverter has very low rise time (it may impact dead zone, i am not so sure). But beta around 2 might cause problems, but i have idea abut you technology so be care full while choosing beta, in earlier my design beta around 3. Thanks, Raj. |
Title: Re: Digital sizing for RF: PFD Post by mixed_signal on Dec 31st, 2012, 10:15am Hi raja.cedt, I am using IBM 130nm tech. So, how beta should be selected 1) symmetric swing i.e. equal rise and fall time i.e beta=3.5 etc. OR 2) Highest speed beta=2 Thanks! |
Title: Re: Digital sizing for RF: PFD Post by raja.cedt on Dec 31st, 2012, 1:00pm use 3.5. What do you mean by high speed beta? Thanks, Raj. |
Title: Re: Digital sizing for RF: PFD Post by mixed_signal on Dec 31st, 2012, 5:58pm High speed beta means that the ratio for which sum of tpLH + tpHL is minimum. To get an intuitive appeal: If you design a ring oscillator with inverters sized for minimum delay then the oscillator will have the highest frequency. Since in my RF design both speed and power is a concern, I was wondering if there is some optimal sizing |
