https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Gain measurement using S21 and transient simulations using Cadence Spectre https://designers-guide.org/forum/YaBB.pl?num=1357007269 Message started by Sharath Raju on Dec 31st, 2012, 6:27pm |
Title: Gain measurement using S21 and transient simulations using Cadence Spectre Post by Sharath Raju on Dec 31st, 2012, 6:27pm Hi, I am trying to measure the gain of a low noise amplifier designed using MOS technology in Cadence. The LNA is a made of an NMOS in common source configuration operating at 10 GHz (narrow-band). S-parameter simulations reveals the gain S21 to be 10.6 dB or 3.4 V/V. I wanted to verify the gain value using transient simulations and replaced the input and output ports using "vsin in series with 50 ohm resistance" and a 50 ohm load resistance respectively. I applied a 1 mV amplitude, 10 GHz sine-wave at the input and see a 4.61 mV amplitude sine wave at the output, suggesting a gain of 4.61 V/V Why is there a discrepancy between S-parameter and transient simulation. ? Am I missing something ? Attached are the testbenches of the S-parameter and transient simulations. Thanks, Sharath |
Title: Re: Gain measurement using S21 and transient simulations using Cadence Spectre Post by Sharath Raju on Jan 3rd, 2013, 1:21pm Update: I solved the problem! First off, I learned that there is more to the measurement of gain than simply measuring the S21. The following link talks about three different gains: transducer power gain, operating power gain and available power gain in the context of LNAs. http://www.ek.isy.liu.se/courses/tsek03/SpectreRF_LNA533AN.pdf I followed the above link and re-measured the gain. In the process, I discovered that I had made a few changes to the circuit in between measuring the S21 and transient gain! With the version inconsistency removed, I see an agreement between the values of operating power gain and transient gain :) Note: For those who are looking at the numbers in detail, my design does not have output impedance matching. Therefore the available power gain is negative :o |
Title: Re: Gain measurement using S21 and transient simulations using Cadence Spectre Post by rfidea on Jan 4th, 2013, 2:15am Thank you for updating the thread! I read it from the beginning and thought the results was strange. What can I say, been there, done that (-: |
