https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> disable task by event handler in same module https://designers-guide.org/forum/YaBB.pl?num=1357336435 Message started by RolfK on Jan 4th, 2013, 1:53pm |
Title: disable task by event handler in same module Post by RolfK on Jan 4th, 2013, 1:53pm Dear Experts, I run into a problem I,m not sure about. What I want to do is call a task by some event (always@(event)) and (as the task may be still executing) disable it before calling it again. I think I need to execute the task inside a fork join block. But this seems not to work. If the task is started once (evtDebug7 is seen) it will not be triggered again, even the event condition in the sourounding always block is matching. Code:
Hope someone can tell me to make this right. Thanks a lot RolfK |
