https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> cadence forum https://designers-guide.org/forum/YaBB.pl?num=1358960217 Message started by satya391 on Jan 23rd, 2013, 8:56am |
Title: cadence forum Post by satya391 on Jan 23rd, 2013, 8:56am How to measure delay of ADC designed in cadence spectra ? |
Title: Re: cadence forum Post by Geoffrey_Coram on Jan 24th, 2013, 11:30am You're going to have to provide more information. For example: what kind of adc? I'm not sure your question even makes sense for a sigma-delta converter. |
Title: Re: cadence forum Post by satya391 on Jan 28th, 2013, 5:35am Thank you for reply I have designed a 6 bit Flash ADC in cadence spectra. How to measure maximum speed of ADC. Also how to find INL,DNL plot. |
Title: Re: cadence forum Post by sheldon on Jan 29th, 2013, 5:49pm Satya, Assuming you have access to Virtuoso, IC61x, in the ahdlLib are example components to measure INL and DNL of a data converter. The examples are for 8 bit data converters, you will need to change the variables for your designs and update the pins. I am perplexed by your request for a delay measurement. While delay can be measured for data converter, performance is usually unrelated to data converter delay. You might find it more useful to perform a parametric sweep of the clock frequency and measure the data converter parameters: THD, SFDR, SNDR, ... and decide based on the performance across frequency what the maximum performance is. All these functions are available in the IC615 version of ViVA when using the spectrum function. Best Regards, Sheldon |
Title: Re: cadence forum Post by satya391 on Jan 30th, 2013, 3:30am Thank you for your essential guidance. Sir,Actually I am working on TIQ ADC and don't give clk so how to know sampling rate (like 1Gs/s).please help me. |
