https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Unbalanced rise/fall time of class-AB output https://designers-guide.org/forum/YaBB.pl?num=1360730443 Message started by ywguo on Feb 12th, 2013, 8:40pm |
Title: Unbalanced rise/fall time of class-AB output Post by ywguo on Feb 12th, 2013, 8:40pm Hi Guys, I have a rail-to-rail output opamp with class-AB output, which is shown in the following picture. I am confused that its rise time is much bigger than its fall time. The opamp is configured into a non-inverting 2X gain mode. Any comments are appreciated. Yawei |
Title: Re: Unbalanced rise/fall time of class-AB output Post by ywguo on Feb 12th, 2013, 9:31pm The input signal is red and the output is blue in the following picture. |
Title: Re: Unbalanced rise/fall time of class-AB output Post by Lex on Feb 13th, 2013, 7:02am How do the voltage nodes 'push' and 'pull' look like? |
Title: Re: Unbalanced rise/fall time of class-AB output Post by Vladislav D on Feb 13th, 2013, 2:31pm The rise/fall time is defined by the tail/cascode currents and the compensation cap, not by the output stage! To make edges symmetrical, the currents should be equal. |
Title: Re: Unbalanced rise/fall time of class-AB output Post by Erez_Sarig on Feb 14th, 2013, 2:03am You Amp is not working in saturation so the Class AB is not the issue here. you apply a large signal. So the reason should be due to NMOS / PMOS output drivers which do not have same resistance. PMOS is not 2X MOS but more 2.5-2.7MOS. Monitor the gates and see they are at maximum opening. Erez Sarig |
Title: Re: Unbalanced rise/fall time of class-AB output Post by Vladislav D on Feb 14th, 2013, 3:12am Erez_Sarig wrote on Feb 14th, 2013, 2:03am:
Wrong. The slewing is defined not by resistance, but by the current and capacitance. Output transistor should operate in saturation, i.e they represent a current source. Now, the question what is larger Icas/Cc or Inmos(Ipmos)/Cload? Btw, output transistors are the part of AB stage and cannot be distinguish from it. |
Title: Re: Unbalanced rise/fall time of class-AB output Post by RobG on Feb 23rd, 2013, 6:06pm I don't read schematics sidewise but I see a few clues. 1) the first pulse is different than the rest so something is probably becoming debiased. 2) The tail current source seems to be very large. 3) The slow rise, fast fall would be consistent with capacitance on the tail current source stealing all the current from the diff pair. Be aware that the diff pair bulk connection to the tail node will add even more capacitance and it isn't modeled. I'd try it in inverting configuration so that the diff pair isn't getting jerked around. (I guess you could make the tail current source ideal). If it works then I'd guess the capacitance on the tail node is stealing your bias current. |
Title: Re: Unbalanced rise/fall time of class-AB output Post by ywguo on Feb 25th, 2013, 8:11pm Lex wrote on Feb 13th, 2013, 7:02am:
Lex, I am sorry to reply late. The nodes push and pull looks like in the following picture. They are obviously unbalanced. :( |
Title: Re: Unbalanced rise/fall time of class-AB output Post by ywguo on Feb 25th, 2013, 10:41pm Hi Guys, The primary factor that results in the slow rise time is the load, a feedback network consisting of 2 resistors. Please look at the test bench for the amplifier step response on the left of the following picture. Is it a wrong choice to drive such a load with class-AB output driver? The rise time reduces a lot if I change to the test bench on the right of the following picture. Best Regards, Yawei |
Title: Re: Unbalanced rise/fall time of class-AB output Post by RobG on Feb 25th, 2013, 10:52pm The properly designed AB is well suited for that load. What are your power supplies? Your output starts out at 0V. Is the supply lower than that? |
Title: Re: Unbalanced rise/fall time of class-AB output Post by ywguo on Feb 26th, 2013, 4:01am Hi RobG, You are correct. The load has nothing to do with the rise/fall time. I made a mistake when I compared two configurations. The output step of the unity gain feedback was half the amplitude of the step of the gain=2 feedback. The supply is single 3.3V. Quote:
The rise/fall time becomes more balanced when I replace the tail current source with an ideal current source. Then I tried to reduce the capacitance of the source node of the diff. pair. It does not improve much. I found the tail current decreases by half when the inp/inm increases. It is curious because that the Vds is still much bigger than Vdsat. In the following picture, net016 is the source of the differential pair, M3/s is the tail current, M1/S and M2/S is the source current of each MOS transistor of the differential pair. net016 increases by near 1.3V, so the parasitic capacitor must have steal some tail current. But why M3/S decreases by almost half? Thanks very much for your help. Yawei |
Title: Re: Unbalanced rise/fall time of class-AB output Post by Lex on Feb 26th, 2013, 5:00am At what voltage are ncas en pcas? |
Title: Re: Unbalanced rise/fall time of class-AB output Post by RobG on Feb 26th, 2013, 7:41am ywguo wrote on Feb 26th, 2013, 4:01am:
OK, I've done that too. The output going all the way to the bottom rail is also going to cause problems so you need to reduce output swing. Capacitance doesn't seem to be your issue; it sounds like you need to make M3 longer to increase the impedance (or make it a cascode device). If there is a way to reconfigure the system to use the opamp in inverting mode it is going to perform a lot better since the tail current source will see the same voltage. |
Title: Re: Unbalanced rise/fall time of class-AB output Post by ywguo on Feb 27th, 2013, 4:22am Lex wrote on Feb 26th, 2013, 5:00am:
Lex, the voltage of ncas and pcas are shown in the following plot. |
Title: Re: Unbalanced rise/fall time of class-AB output Post by ywguo on Feb 27th, 2013, 4:44am Hi RobG, The following is comparison of the original design, the half-size tail current and ideal tail current. The red line is the step response of the original design. The purple line is the step response of the opamp with half-size tail current. The black line is the step response of the opamp with ideal current source. The purple line improves compared to the original design. I will try to improve the tail current source further. Thank you very much. Yawei |
