https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Choosing inductor for low power https://designers-guide.org/forum/YaBB.pl?num=1361131713 Message started by mixed_signal on Feb 17th, 2013, 12:08pm |
Title: Choosing inductor for low power Post by mixed_signal on Feb 17th, 2013, 12:08pm Hi, I have two inductors: L1=2nH Q1=15 Rp1 (Parallel)=450 ohm L2=4nH Q=11 Rp2(Parallel)=500 ohm where Q=Rp/Lw If I use them in VCO I want to know which one will provide low power consumption. I think Rp2 is greater and hence less -gm will be required to start up and hence inductor 2 will be low power consuming. For better phase noise I think 1 is better since Q1>Q2 |
