https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> need solution for following error in rtl synthesis tool in cadence https://designers-guide.org/forum/YaBB.pl?num=1362563389 Message started by aathi27 on Mar 6th, 2013, 1:49am |
Title: need solution for following error in rtl synthesis tool in cadence Post by aathi27 on Mar 6th, 2013, 1:49am reg [7:0]cb[3:0][3:0]; | Error : Verilog-2001 feature. [VLOGPT-3] [read_hdl] : Multiple dimensions in file './sad.v' on line 8, column 22. : The design must be read in with 'read_hdl -v2001'. |
Title: Re: need solution for following error in rtl synthesis tool in cadence Post by Geoffrey_Coram on Mar 6th, 2013, 5:17am Did you read the error message? It says you have to specify -v2001 because you're using a feature that is from a later version of the language than your simulator supports by default. |
