https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> Hspice and verilog A https://designers-guide.org/forum/YaBB.pl?num=1362862096 Message started by conix33 on Mar 9th, 2013, 12:48pm |
Title: Hspice and verilog A Post by conix33 on Mar 9th, 2013, 12:48pm Hello, I am new to the forum and to the modeling world. I am trying to understand how to combine Hspice and verilog . I would like to model a OTFT from a model from Hspice. I am at the planning stage still. I read you can modify a model using Verilog A but I was not able to find how to do it. Please I have some questions I need some answers: - Can someone guide me how to find those info? - Can we modify the equations in the file (and rename it to something else) by using Verilog A? - Are there some OTFT verilog code to use and modify? I appreciate any help. Thank you |
Title: Re: Hspice and verilog A Post by Geoffrey_Coram on Mar 11th, 2013, 11:42am Your first task will be to find a Verilog-A description of an OTFT (I'm not familiar with the acronym). Do you know of any university research groups working on OTFT? You should check their web sites and/or publications. Verilog-A is a language; your second question doesn't really make sense -- you'll modify the equations in the file using a text editor. |
