Design Languages >> Verilog-AMS >> Single line assignment to multiple variable
https://designers-guide.org/forum/YaBB.pl?num=1363693096
Message started by Tobben24 on Mar 19th, 2013, 3:38am
Title: Single line assignment to multiple variable
Post by Tobben24 on Mar 19th, 2013, 3:38am
Hi,
Is it possible to do single line assignment to multiple variables? Something like this:
real one,two,three;
one,two,three = 0;
Title: Re: Single line assignment to multiple variable
Post by Geoffrey_Coram on Mar 20th, 2013, 5:24am
I don't believe the syntax allows
 one,two,three = 0;
I believe the lastest (digital) Verilog supports initialization as part of the declaration:
 real one=0,two=0,three=0;
and I've found some simulators support new digital features in the AMS context.
Of course, if you just want to do it on one line, you could do
 one=0; two=0; three=0;
The statements don't have to be on separate lines.
Post by Tobben24 on Mar 20th, 2013, 6:09am
Okay, thanks for the reply:)
Post by Paul Floyd on Mar 20th, 2013, 8:44am
Tobben24 wrote on Mar 19th, 2013, 3:38am:
Hi,
real one,two,three;
one,two,three = 0;
Variables should be default initialized to zero, so in this case your assignment does nothing. If you want a different value, that's another matter.
If it were allowed, I'd want to follow C++ syntax, where it would be
a = b = c = 0;
A+
Paul
