https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> problem with gated current source https://designers-guide.org/forum/YaBB.pl?num=1363855624 Message started by sourav on Mar 21st, 2013, 1:47am |
Title: problem with gated current source Post by sourav on Mar 21st, 2013, 1:47am Hi, i want to design a gated current source. Here i have used a simple current mirror topology. Current through PM12 and PM13 will be controlled through the signal phi1 and phi2. Before adding these switches i was getting current 128 times of 40nA as I fixed the W/L ratio 128 times of PM10 and PM11. After adding the switches i was expecting current only during the on time of phi2 and zero value when it is off. I have taken here ideal switches and they are implemented in Verilog A with on resistance of 1ohm and Off resistance of 100Mohm. i am using gpdk 180nm technology file in cadence. after the simulation i am getting an unstable current instead of constant current. i have observed several times that whenever i am using some clock in mos circuits it generates some random fluctuation in current at the other terminals. please tell me the reason behind it and give me some suggestion thanks |
Title: Re: problem with gated current source Post by Geoffrey_Coram on Mar 25th, 2013, 7:37am It's tricky to write a good switch model in Verilog-A. Did you try using a built-in switch provided by your simulator? |
Title: Re: problem with gated current source Post by Kevin Aylward on Jul 7th, 2013, 3:52am Without even examining anything about your circuit, but based on the graphs only, I would first suggest that you set the simulator to do “Gear only” for these runs. |
