https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> NCSU FreePDK45 problem https://designers-guide.org/forum/YaBB.pl?num=1366005969 Message started by emax00 on Apr 14th, 2013, 11:06pm |
Title: NCSU FreePDK45 problem Post by emax00 on Apr 14th, 2013, 11:06pm I installed NCSU FreePDK45 with correct paths and setup files and can see the following two libraries in the library manager of virtuoso. 1) NCSU_TechLib_FreePDK45 2) NCSU_Devices_FreePDK45 However, when I create a new library and try to attach the NCSU_TechLib_FreePDK45 techfile, I receive the following error: "The binary file tech.db was not found in the library NCSU_TechLib_FreePDK45" But the tech.db file is there in the NCSU_TechLib_FreePDK45 folder. How to fix this problem? Also, if I have the TSMC 0.18um design kit, how to find out if it is OA or CDB compatible? |
