https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> .cdsinit not being read at startup. https://designers-guide.org/forum/YaBB.pl?num=1366010943 Message started by Sharath Raju on Apr 15th, 2013, 12:29am |
Title: .cdsinit not being read at startup. Post by Sharath Raju on Apr 15th, 2013, 12:29am Hi, At Virtuoso startup, I expect the initialization file .cdsinit to be read provided the it is present either in the "<my_cadence_installation_dir/tools/dfII/local" directory or the current working directory or the user's home directory. I copied the sample .cdsinit file from "<my_cadence_installation_dir/tools/dfII/samples" to my current working directory and made the following simple change: setenv EDITOR "gedit" Unfortunately, I see that the cdsinit is not being loaded. The way I verified this is to open some verilog-A files from within virtuoso and see that it always uses xedit to open the files. Further, even if I put some garbage text into the .cdsinit file, virtuoso continues to launch without any problem. Is my assumption that .cdsinit is automatically loaded incorrect? If so, what should I do to correctly load .cdsinit? Thanks, Sharath |
