https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> ocean script https://designers-guide.org/forum/YaBB.pl?num=1369233827 Message started by Evgenii on May 22nd, 2013, 7:43am |
Title: ocean script Post by Evgenii on May 22nd, 2013, 7:43am Hi! I use OCEAN Script for simulations. In process to calculation (if i use 'sweep' for many corners and parameters), information in CIW is unreadable and command window frequently 'freezes'... How to display number or name of current simulation in other way (but in CIW preferable) . Or it possible only to write to file or as label in Waveforms window... Thanks! :) PS I think is possible to do if disable plotting the curves during simulation... :) theme must be closed, sorry ;) |
Title: Re: ocean script Post by boe on May 23rd, 2013, 2:50am Evgenii, the CIW 'freezes' because it is busy. printf/fprintf can be used to print. - B O E |
