https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to make Cadence plot output expression in new subwindow https://designers-guide.org/forum/YaBB.pl?num=1370086200 Message started by jqjqjq on Jun 1st, 2013, 4:29am |
Title: How to make Cadence plot output expression in new subwindow Post by jqjqjq on Jun 1st, 2013, 4:29am Dear all, I'm using cadence with IC5141USR6 (or rather, 5.10.41_USR6.127.29). I set 9 output expressions, and after simulation, the expressions are plotted in one window and one subwindow However, I really need them to be divided into 3 groups, each group has 3 expression, and each group correspond to one subwindow. The resulting 3 subwindow should be in one window. I believe OCEAN script could implement my intention. But I want to use the GUI, but not script. So is there any solution? I really did not find any choice or button like "Append, Replace, New Subwindow, New Window" in the output expression setup window. Thank you all in advance. jq |
