https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> trouble in simulating verilog-AMS code using Virtuoso ADE https://designers-guide.org/forum/YaBB.pl?num=1375027498 Message started by susona on Jul 28th, 2013, 9:04am |
Title: trouble in simulating verilog-AMS code using Virtuoso ADE Post by susona on Jul 28th, 2013, 9:04am Hai i generated verilog code from model writer function in cadence and created symbol for that. i used this symbol to create the test bench for ADC the problem is in my code i defined output as dout as a 8 bit register but when i created the test bench and netlist it is taking individual bits so i am getting error in simulation can any one help me how to simulate this in virtuoso ADE |
Title: Re: trouble in simulating verilog-AMS code using Virtuoso ADE Post by Geoffrey_Coram on Aug 2nd, 2013, 8:46am Does your symbol have a bus pin or individual bit pins? |
Title: Re: trouble in simulating verilog-AMS code using Virtuoso ADE Post by susona on Aug 2nd, 2013, 9:32am in my symbol i have only bus pin |
