https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> deep nwell isolation effectiveness https://designers-guide.org/forum/YaBB.pl?num=1376011266 Message started by RobG on Aug 8th, 2013, 6:21pm |
Title: deep nwell isolation effectiveness Post by RobG on Aug 8th, 2013, 6:21pm Hi All, I have a vague memory of someone (loose-electron?) saying they did some studies on deep Nwell isolation and found that the noise isolation improvements were minimal. Was the issue that you could not contact it at a low enough impedance? Any (decent) papers on the subject? rg |
Title: Re: deep nwell isolation effectiveness Post by loose-electron on Aug 18th, 2013, 11:56am yes - we did some real world studies and the deep well does not help that much in most cases (2-4dB) (IBM, SiGe processes with deep-n-well 6HP IIRC) At high frequencies, coupling is going to be by parasitic paths and the deep wells do not make parasitics go away by magic. |
