https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> CMOS Self-Biased Cascode Power Amplifier https://designers-guide.org/forum/YaBB.pl?num=1378636848 Message started by baab on Sep 8th, 2013, 3:40am |
Title: CMOS Self-Biased Cascode Power Amplifier Post by baab on Sep 8th, 2013, 3:40am Hi, I am studying the article "A 2.4-GHz 0.18-um CMOS Self-Biased Cascode Power Amplifier" (attached). Here are what I am confused. Please help. Thank you. |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by baab on Sep 8th, 2013, 3:41am Second image. |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by baab on Sep 8th, 2013, 3:46am The article: |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by raja.cedt on Sep 8th, 2013, 5:12am Hello, I am not an RF expert, i will try to ans what i know. 1. Dc choke you can't integrate on chip, in principle RC or LC works fine. 2. min value of Cascode gate voltage should be equal to Vth+2*vov and max below Vo+vth, since there is an inductor at the o/p DC operating point is around vdd, so Vdd at gate make scene. 3. I guess this is to create 50 Ohm or required real input impedance with out having noisy resister at the input... Thanks, Raj. |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by baab on Sep 8th, 2013, 5:36am Thank you, Raj. Quote:
I am not sure but I usually see that RF choke is used in chips. But inductor will be better than resistor? I think if we use resistor, there will be some energy dissipated thermally. If inductor is used no RF signal flows through it and no losses but when the resistor Rg is used RF signal will flow through it to ground and causes losses. Quote:
Vth + 2Vov < Vbias < Vo + Vth I have read cascode configuration and this is metioned too. But how can you know the values of Vov and Vo? :-[quote]3. I guess this is to create 50 Ohm or required real input impedance with out having noisy resister at the input...[/quote] Sorry, is this the answer for Q3? |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by baab on Sep 8th, 2013, 8:11am I have seen this conventional cascode configuration amplifier. Please help me with this question too. |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by raja.cedt on Sep 8th, 2013, 9:39am Lg1,Lg2 are bondwire inductance (Just because they are after the pad) Rg1,Rg2 are biasing resisters. Ls1 also bondwire inductance but it will be used to create real Zin |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by aaron_do on Sep 8th, 2013, 6:03pm Hi, Ls1 is a bond-wire inductance which changes the real part of the input resistance, but I wonder if it is deliberately added, and not just part of the model. It can help to improve the linearity, but there are a few tradeoffs. 1. Stability may be degraded due to feedback. 2. Maximum output power is potentially lowered. Check the voltage swing at the drain and source. If they are out-of-phase, then your maximum output power is lowered. 3. Maximum efficiency may drop. For a given supply voltage, if the swing at the output is reduced, the peak efficiency may also drop. 4. Maximum power gain is reduced. This follows from the drop in input impedance, and the drop in Gm. You might want to check this, but just intuitively I think its true. As far as I know, Ls1 is not typically added in a power amplifier (especially the output stage), but is extremely common for LNA design. Second issue. As Raja.cedt said, Rg1 and Rg2 do not cause any loss as long as they are large enough. RF chokes are very large and aren't really implementable on chip. However, if ACPR or your spectrum mask requirements are stringent, then you may find the use of biasing resistors problematic. I can't remember the exact theory, but I believe if you do a volterra series analysis of a nonlinear impedance, you will find that the "baseband impedance" (actually any harmonic impedance I think) can affect the intermodulation performance. Using an RF choke allows you to make the baseband impedance equal to zero. Transformer matching does the same thing. It really depends on your application, but you may want to bear it in mind. regards, Aaron |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by tm123 on Sep 9th, 2013, 10:18am My comments: 1) The transistors need to be biased in saturation, and biasing the cascode gate at VDD provides maximum headroom to M1. This is important for linearity especially with voltage swing at node D1. Ideal analysis usually assumes that the Zin of the cascode (looking in to the source of M2) is zero but it is really 1/gm of M2 which can be quite large in MOS depending on the bias current and M2 W/L 2) RF choke inductor is not practical to implement on chip because it is very area inefficient. A large resistor is sufficient to provide a large impedance at RF. Something like 10K-20K ohm should do it. 3) In a single ended design like this you are stuck with bondwire inductance between the source of M1 and the actual ground. You can use this inductance to your advantage since inductance at the source makes the small signal input impedance of the amplifier look like a purely real impedance, i.e. resistance (this is a good derivation to do and have for reference). If designed properly you can obtain a reasonable impedance match without using a shunt resistor that causes loss (not good if you care about noise figure). The inductance also provides some degeneration which will improve linearity. I am not sure what your ultimate goal is but it has been my experience that trying to learn design from IEEE papers is extremely difficult because the authors assume you have certain basic knowledge and often times leave out important design details. If you are trying to learn about design I suggest using textbooks by authors such as Thomas Lee and Behzad Razavi since they start from very basic principles and build up to more complex topics. |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by baab on Sep 19th, 2013, 12:32am Thank you, aaron_do and tm123. I really appreciate your helps. Aaron: Quote:
With input resistance, do you mean output resistance of the previous stage (usually 50 or 75 ohms)? If I understand you correctly, L1 is also added to help in input matching network. It will be used to compensate Cgs, Cgd and other capacitive components. Quote:
Could you tell me how it improve the linearity? I don't want to take you a lot of time, so please give me a link or some keywords therefore, I can search it myself. English is not my native language and I feel a bit difficult in finding keywords. Quote:
I don't know why stability is degraded. I think it should be upgraded because negative feedback. However, power gain is decreased due to the feedback. Quote:
Is it because when they are out of phase => Vds > 0 and there is part of power dissipated in MOSFET? Quote:
Yes, I see it. :) Quote:
Yeah. Quote:
I guess its role is to reduce noise figure, NF. Quote:
I don't get this. For Rg1, Rg2 to be bias resistor, it has to be as small as possible to reduce power losses. However, with RF signal, to reduce losses of RF signal, Rg1, Rg2 has to be as big as possible. Then there is a trade-off here. But you said it causes no losses. I am really confused about this. Because resistances, I think there are always losses in these components. |
Title: Re: CMOS Self-Biased Cascode Power Amplifier Post by aaron_do on Sep 19th, 2013, 1:28am Hi baab, Quote:
No, I mean the input resistance of the PA (not the previous stage). You can do some reading on the "inductive degeneration" technique for LNA design to understand what I mean. It is a feedback technique which is used to add a real part to the input impedance. Without it, the input impedance of would be mostly capacitive. It may partially compensate Cgs or Cgd, but that is not its main purpose for input matching. Quote:
Its been a while, so I can't think of any references, but Ls1 is a source-degeneration inductor. It provides negative feedback and therefore should improve the linearity. However, I don't think it provides much negative feedback, and so it probably doesn't improve linearity very much. Quote:
Instability is caused by unwanted positive feedback. Ls1 may provide positive feedback at some frequency that you didn't pay enough attention to. It completely depends on your design. When your design is at a very high frequency, or high power, you will see all kinds of unwanted feedback paths causing problems, and a simpler design is easier to manage. I'm not sure if stability is ever "upgraded" due to negative feedback. Quote:
Its not directly because of any power dissipated in the transistor, although that might factor in too. Maximum output power depends on the maximum swing that can be generated at the output. The minimum that the drain voltage can swing is equal to the source voltage + the drop across the transistor. This will in turn determine the maximum swing. So you ideally don't want your source voltage swinging out-of-phase wrt the drain voltage. Quote:
Yes that's true for an LNA, but its not very important for a PA. Quote:
You seem to have a misunderstanding here which is quite common. Rg1 and Rg2 are in parallel with the signal path. Ideally you don't want any power from your main signal to pass through the resistors. Therefore, the larger they are, the less the loss. It has nothing to do with RF. Just like an insulator surrounding any wiring. The insulator is in parallel with the signal path, and so you want it to have as high a resistance as possible. When I said no losses I meant negligible losses. That said, the issue I was referring to (about the intermodulation performance) is a bit deeper, so maybe you should just ignore it for now. hope it helps, Aaron |
