https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> ADC conversion doesn't behave as expected. Adaptation required? https://designers-guide.org/forum/YaBB.pl?num=1379664883 Message started by Damaso on Sep 20th, 2013, 1:14am |
Title: ADC conversion doesn't behave as expected. Adaptation required? Post by Damaso on Sep 20th, 2013, 1:14am I've designed a Galvanostat (meassures the voltage drop vs time in a sample while applying a constant current) and the final ADC conversion shows some extrange behaviour. Instead of showing a continous variation in the voltage meassured, it show a ramp-like conversion. Meaning, the conversion is constant for a few samples, providing the exact same 16bits value, and then jumps to the next voltage value. This behaviour is more visible as the rate of change in voltage lowers. I tried changing the ICs in the circuit, changing the experiment conditions and many other things, but the problem seems to be in the way the ADC reads the data. I was using a multimeter to read the in voltage and, strangely enough, while the multimeter was connected, this behaviour disappeared and the conversion went as expected, but a bit of noise was added. I suppose that the multimeter pressence stabilized somehow the ADC reading, but i wasn't able to recreate it on my own. Here are some images of my circuit and the curves I got from different same-conditions experiments. The one in black is meassured with the multimeter connected. It is of note than the other three show the exact same "stairs" at the same voltage values. Can anyone please give me a hint of what may be happening? |
Title: Re: ADC conversion doesn't behave as expected. Adaptation required? Post by Damaso on Sep 20th, 2013, 1:15am And here is the schematics of the part of the circuit involved. I'm only showing the last past of the signal path, which I think is the only part relevant for my question. Sorry for the double post, but I don't know how to attach more than one image |
