https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Cases design for RF product (simulation softwares) https://designers-guide.org/forum/YaBB.pl?num=1381835696 Message started by Tarikm on Oct 15th, 2013, 4:14am |
Title: Cases design for RF product (simulation softwares) Post by Tarikm on Oct 15th, 2013, 4:14am Hi everyone, We are working on a RF bluetooth product, the first proposed design for the case was some kind of Aluminum cylinder, I think this design will create a lot of troubles since the RF antenna will be printed on the PCB and the Al case will act like a shield for electromagnetic waves. Is putting a big enough cavity on the design helpful to avoid such problems ? and what are the best suited simulation softwares to use for simulating the case effect (if there is a free software it will be great). Thank you for your help |
Title: Re: Cases design for RF product (simulation softwares) Post by harpoon on Oct 17th, 2013, 2:28am I have not done such large scale modelling before ... but half the battle is setting up the simulator and the test bench. I am guessing something like HFSS will do it, probably ADS Momentum (pricey) Mentor has some 2.5D/3D solvers for PCB ... can't remember what is called. Probably have something in Cadence as well ... On the lower end, maybe Eagle ? And the free ones ... maybe, just maybe ASITIC or FastHenry can give some guidance (they were written for inductor extraction/modelling). good luck ! |
