https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Generating baseband data for TX using AWG https://designers-guide.org/forum/YaBB.pl?num=1383881823 Message started by mixed_signal on Nov 7th, 2013, 7:37pm |
Title: Generating baseband data for TX using AWG Post by mixed_signal on Nov 7th, 2013, 7:37pm Hi, I am testing my TX which is a MUX based TX for pi/4 DQPSK modulation. I am using an AWG to generate the random binary sequence for the state machine controlling the MUX. First I tried the sequence so that all phases (0,45,90,...315) get transmitted. The corrs dig seq is 00011011 . But due to periodicity of this sequence the output spectrum has narrow lobes. Then I tried a 2000 bit random sequence but still I have those lobes. 1. What is the standard method of generating sequences for testing TX. If random what should be the length of the sequence? 2. Is there a way to look into the PSD of a random binary sequence? IN MATLAB? |
Title: Re: Generating baseband data for TX using AWG Post by ywguo on Nov 22nd, 2013, 8:25pm What is the period of your 2000 bit random sequence? |
