https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Port in cadence https://designers-guide.org/forum/YaBB.pl?num=1383924935 Message started by baab on Nov 8th, 2013, 7:35am |
Title: Port in cadence Post by baab on Nov 8th, 2013, 7:35am Hi, I am reading this guideline about port in Cadence. Could you explain a bit more about #1 and #3? port Capabilities While the port component is generally useful as a stimulus in high-frequency circuits, it also has the following unique capabilities: 1. Defines the ports of the circuit to the S-parameter analysis 2. Has an intrinsic noise source that lets the noise analysis directly compute the noise figure of the circuit 3. Is the only source for which the amplitude can be specified in terms of power |
Title: Re: Port in cadence Post by sheldon on Nov 9th, 2013, 3:23am Baab, 1) Spectre's s-parameter analysis recognizes and uses port numbers 3) For the port, user can define the input level directly in terms of power. For other sources, users need to write equations to convert power into voltage so the port is easier to use. Sheldon |
