https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Need some help explain the curves of Vg and id https://designers-guide.org/forum/YaBB.pl?num=1390743312 Message started by baab on Jan 26th, 2014, 5:35am |
Title: Need some help explain the curves of Vg and id Post by baab on Jan 26th, 2014, 5:35am Hi, I am simulating rfnmos1v in TSMC 0.13 with the set up as follows: Generally, I swept Io and plot ig, id, Vg, Io accodring to Io. Could anyone help me explain the theory behind the curves of Vg and id. I can't explain why they have the shape like that. As in the picture,ig = 0 all the time. In the initial stage, id = Io. However, after Io > 0.3A, id almost saturated and not increase much.I am wondering why id isn't equal to Io after that time. BTW, I drew the small signal model but that doesn't make sense at all as the circuit has no independent source, the only dependent current source here is gm*Vgs, and I can't calculate anything. Here is the circuit for simulation: |
Title: Re: Need some help explain the curves of Vg and id Post by baab on Jan 26th, 2014, 5:39am Here is the set up: |
Title: Re: Need some help explain the curves of Vg and id Post by baab on Jan 26th, 2014, 5:44am Here is the result: |
Title: Re: Need some help explain the curves of Vg and id Post by aaron_do on Jan 26th, 2014, 4:38pm Look at your y-axis. You are using a 1-V transistor. Looks like you're pumping way too much current through the device. Aaron |
Title: Re: Need some help explain the curves of Vg and id Post by baab on Jan 26th, 2014, 7:46pm Thank you. You are right. I am using 1V transistor. In that case, the transistor is breakdown? |
Title: Re: Need some help explain the curves of Vg and id Post by aaron_do on Jan 26th, 2014, 10:04pm The transistor would definitely breakdown in practice, but the transistor model doesn't extend into that region. I'm not sure what is happening with the model at that point. The equations could be meaningless, or maybe some diode has turned on...not really sure. regards, Aaron |
