Simulators >> Circuit Simulators >> How can I sweep actimes in trans analysis?
https://designers-guide.org/forum/YaBB.pl?num=1392109051
Message started by aaron_do on Feb 11th, 2014, 12:57am
Title: How can I sweep actimes in trans analysis?
Post by aaron_do on Feb 11th, 2014, 12:57am
Hi all,
I'm using Spectre Trans analysis, and I want to sweep the option actimes. Does anybody know how?
thanks,
Aaron
Title: Re: How can I sweep actimes in trans analysis?
Post by Andrew Beckett on Feb 16th, 2014, 12:38am
Well, you can add a sweep around the analyses which is varying the actimes - as follows:
Code:
parameters act=0.5u
V1 (in 0) vsource type=sine mag=1 freq=1M ampl=1.2
R1 (in out) resistor r=1k
C1 (out 0) capacitor c=1p
sweepact sweep param=act start=0.1u stop=0.8u step=0.1u {
� �ac ac start=1 stop=1G
� �tran tran stop=1u acnames=[ac] actimes=[act]
Of course this is a completely silly example...
I suspect this is not what you're asking (it wasn't very precise). Are you asking to do a single transient where the actimes is a sweep rather than a list of literal values? If so, you can't do that... you should contact http://support.cadence.com as it's a reasonable request for an enhancement.
Andrew.
Post by aaron_do on Feb 16th, 2014, 6:06pm
Hi Andrew,
thanks for the reply. Yeah I see that in your example I would need to run N times as many analyses. Right now I need to type in each actime that I want included. See if I get around to contacting support...
thanks,
Aaron
Post by boe on Feb 18th, 2014, 10:50am
Hi Aaron,
I recently asked the support for that. The answer I got:
"as for tran and actimes there is yet no such advanced �acperiod� option, you could also do a for loop and run a tran for each code."
- B O E
