https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> RMSjitter contribution of chargepump to pll o/p. factor of 2 after integ or not? https://designers-guide.org/forum/YaBB.pl?num=1392284490 Message started by yvkrishna on Feb 13th, 2014, 1:41am |
Title: RMSjitter contribution of chargepump to pll o/p. factor of 2 after integ or not? Post by yvkrishna on Feb 13th, 2014, 1:41am Hi, I am running pnoise simulations using spectre on chargepump. I get a noise profile of chargepump which has flicker noise+thermal noise floor. analytically also it should be a scaled version of current source noise with duty cycle of the square wave as shown in.. http://www.designers-guide.org/Forum/YaBB.pl?num=1389088736/1#1 since this is already 2 sided noise PSD ( which is in the form of 4kTgm ) I think we just need to integrate the noise psd (in the pll bandwidth) and multiply with PLL transfer function to output while estimating rms jitter. However I have noticed many designers and journal papers using a factor of after integration. Please clarify whether a factor of 2 is needed or not and why ? Thanks, yvkrishna |
