https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Signal flow graph for two-port network https://designers-guide.org/forum/YaBB.pl?num=1393321689 Message started by baab on Feb 25th, 2014, 1:48am |
Title: Signal flow graph for two-port network Post by baab on Feb 25th, 2014, 1:48am Hi, this is part of an application note entitled "Low-Noise Amplifier Stability Concept to Practical Considerations" from Maxim. Could you help me with the question in the picture? Thanks. Source: http://www.maximintegrated.com/appnotes/index.mvp/id/1849 |
Title: Re: Signal flow graph for two-port network Post by aaron_do on Feb 25th, 2014, 9:14pm Hi baab, from the diagram, it looks like bs2 is a1*S21 under the condition that ΓL = *ΓOUTBut if that's the case, then bs2 = S21.bs/(1-S11ΓS) so either I'm wrong or there's a typing error... normally if there is reflection at the load, the power will go back to the device, and some of the power will reflect back to the load through S22, and some will take the longer path, S12ΓSS21, and then you could even have multiple reflections etc. However, setting the condition ΓL = *ΓOUT ensures that any power reflected at the load will never find its way back to the load again. So I'm thinking you can calculate the power to the load with the S12 path removed. That's how I got the formula above. Unfortunately, I don't have any of my RF references handy and I haven't looked at this stuff in a while... regards, Aaron |
Title: Re: Signal flow graph for two-port network Post by baab on Mar 8th, 2014, 10:58pm Thank you. I have spent a long time reading about S parameters and got basic understanding about it. I found the great lecture here: http://www.ittc.ku.edu/~jstiles/723/handouts/section_4_5_Signal_Flow_Graphs_lecture.pdf And you are right. That is a typo. |
