https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> call an analog function from another analog function? https://designers-guide.org/forum/YaBB.pl?num=1393544224 Message started by Vince Lee on Feb 27th, 2014, 3:37pm |
Title: call an analog function from another analog function? Post by Vince Lee on Feb 27th, 2014, 3:37pm Is it OK to call an analog function from another analog function? For example, /*****example start*****/ analog function real f1; input x; real x; begin f1 = x*2; end endfunction analog function real f2; input x; real x; begin f2 = f1(x)+1; end endfunction /*****example end*****/ Thanks! |
Title: Re: call an analog function from another analog function? Post by Andrew Beckett on Feb 28th, 2014, 9:53am Yes. I tested this (I couldn't see why it shouldn't work) in both spectre with a VerilogA module and in AMS Designer with a VerilogAMS module, with no problems. Regards, Andrew. |
