https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> tune out a wideband balun? https://designers-guide.org/forum/YaBB.pl?num=1393741382 Message started by mixed_signal on Mar 1st, 2014, 10:23pm |
Title: tune out a wideband balun? Post by mixed_signal on Mar 1st, 2014, 10:23pm Hi, I am trying to implement a wideband balun as an intermediate stage in a CMOS receiver. I want to have Real(Zin)=Rload where Zin is input impedance looking to primary when secondary has a load Rload in 1:1 balun with l1=l2=1nH and k=1 . (ideal) Is it necessary to tune out the inductors of the balun? I yes then it becomes a narrowband system. If I dont tune then Zin, Real (Zin) becomes inductive and has very low real part. |
Title: Re: tune out a wideband balun? Post by aaron_do on Mar 9th, 2014, 8:44pm Hi mixed_signal, you do need to resonate the balun in order to minimize loss. However, as I remember it, the balun will give you a wider bandwidth than if you had used an LC. Also, for high impedance ratios, baluns are also less lossy. I wish I had my previous references with me so I could give more information, but it would be quite a chore finding them since I changed jobs. There are papers on power amplifier design which do a lot of analysis on baluns if you are interested. If I remember correctly, look for an author named Ichiro Aoki formerly from Axiom... regards, Aaron |
