https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> HBNOISE Convergence Issue https://designers-guide.org/forum/YaBB.pl?num=1394302197 Message started by tm123 on Mar 8th, 2014, 10:09am |
Title: HBNOISE Convergence Issue Post by tm123 on Mar 8th, 2014, 10:09am Hello All, I am working on an LC oscillator design and trying to simulate the phase noise using SpectreRF HB/HBNOISE analysis. This has worked well for me in the past, but now with a newer version of MMSIM I see these messages in my output log during the HBNOISE analysis: Warning: GMRES did not converge to the desired tolerance of 0.0001. It actually converged to 0.000129598. The solution may not be accurate but it's saved anyway. Warning: GMRES did not converge to the desired tolerance of 0.0001. It actually converged to 0.00288411. The solution may not be accurate but it's saved anyway. hbnoise: freq = 10 kHz (0 %), step = 10 kHz (0 %) Warning: GMRES did not converge to the desired tolerance of 0.0001. It actually converged to 0.000131274. The solution may not be accurate but it's saved anyway. Warning: GMRES did not converge to the desired tolerance of 0.0001. It actually converged to 0.00405571. The solution may not be accurate but it's saved anyway. hbnoise: freq = 100 kHz (33.3 %), step = 90 kHz (33.3 %) Warning: GMRES did not converge to the desired tolerance of 0.0001. It actually converged to 0.000128369. The solution may not be accurate but it's saved anyway. Warning: GMRES did not converge to the desired tolerance of 0.0001. It actually converged to 0.00204469. The solution may not be accurate but it's saved anyway. hbnoise: freq = 1 MHz (66.7 %), step = 900 kHz (33.3 %) Warning: GMRES did not converge to the desired tolerance of 0.0001. It actually converged to 0.00219455. The solution may not be accurate but it's saved anyway. hbnoise: freq = 10 MHz (100 %), step = 9 MHz (33.3 %) Does anyone have experience with these warnings and how to improve GMRES convergence? Also, I am running MMSIM13.1. Thanks, Tim |
Title: Re: HBNOISE Convergence Issue Post by Andrew Beckett on Mar 8th, 2014, 11:55pm Tim, You should contact Cadence customer support at http://support.cadence.com over this, especially if you're using the latest MMSIM13.1 Hotfix (13.1 ISR4). Kind Regards, Andrew. |
Title: Re: HBNOISE Convergence Issue Post by tm123 on Mar 9th, 2014, 10:05am Hello Andrew, Thank you for your response. We are not running MMSIM13.1 hotfix. We will install that and see if this solves the problem. If not, we will contact Cadence support. Thanks again, Tim |
Title: Re: HBNOISE Convergence Issue Post by tm123 on Mar 14th, 2014, 6:10pm Hello Andrew, Just a quick update, we installed MMSIM13.1 ISR4 and the GMRES convergence issue was not resolved so I have started the process of getting Cadence support involved. I have been searching the documentation for an explanation of GMRES convergence issues and I can not find any description of this or any method to improve the convergence. Can you point me to any Cadence document that describes possible causes for this and any possible solutions? Are there any simulation settings I can adjust to improve the GMRES convergence? My initial thought is to disregard any simulation result when I seen this warning, since it is not clear how accurate the result is. Thanks, Tim |
Title: Re: HBNOISE Convergence Issue Post by Andrew Beckett on Mar 16th, 2014, 1:22am Hi Tim, You might want to try this parameter on hbnoise: Code:
You'll need to set this via the additionalParams field on the hbnoise options form. Not sure about whether you can trust the results as is (it's reasonably rare to get this GMRES message) - and that's why it is important to work with customer support on this. A little bit of info on GMRES can be found at http://en.wikipedia.org/wiki/Gmres Regards, Andrew. |
Title: Re: HBNOISE Convergence Issue Post by cktdesigner on Nov 20th, 2014, 8:53pm Andrew Beckett wrote on Mar 16th, 2014, 1:22am:
Hi Andrew, Could you please tell which manual is the information given above by you taken from? I am trying to dig for more information about this krylov_size parameter for including it in my simulations as well. Many thanks, cktdesigner |
Title: Re: HBNOISE Convergence Issue Post by Frank Wiedmann on Nov 21st, 2014, 12:54am A better forum for questions like this is http://community.cadence.com/cadence_technology_forums/f/33. I did a quick search on http://support.cadence.com/ and did not find any other information about the krylov_size parameter than what was given by Andrew. Solution 20184596 (http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20184596) suggests that the convergence problems are fixed in MMSIM 13.1 ISR5. |
Title: Re: HBNOISE Convergence Issue Post by cktdesigner on Nov 21st, 2014, 1:11am Frank Wiedmann wrote on Nov 21st, 2014, 12:54am:
Hi Frank, The version of spectre installed at my end is 12.1 I do not have access to MMSIM 13.1. But thanks for your comment anyway. |
