https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Cgs and Cgs vs Vgs https://designers-guide.org/forum/YaBB.pl?num=1394849162 Message started by baab on Mar 14th, 2014, 7:06pm |
Title: Cgs and Cgs vs Vgs Post by baab on Mar 14th, 2014, 7:06pm Hi. I set up this circuit for simulation Cgs and Cgs as Vgs changes. Below are the curves Cgs and Cgs vs Vgs. (please see it in the second post. The forum doesn't allow to post two images in a single post) I have some questions, hope you can help. 1. Why Cgs and Cgs are negative? 2. Why Cgs and Csg are not equal? Thanks. |
Title: Re: Cgs and Cgs vs Vgs Post by baab on Mar 14th, 2014, 7:07pm And this is the curves Cgs and Cgs vs Vgs: |
Title: Re: Cgs and Cgs vs Vgs Post by aaron_do on Mar 16th, 2014, 10:18pm Hi baab, I think this has been discussed more than once before, but you will need to do a search. I believe it is just something to do with the way capacitance is defined in the model which makes it a negative value. Also, Cgs and Csg may not be defined exactly symmetrically. For your purposes (matching I assume), I guess you're probably better off doing an AC or SP analysis to find the capacitance since all the capacitance will be lumped together... regards, Aaron |
Title: Re: Cgs and Cgs vs Vgs Post by baab on Mar 16th, 2014, 10:38pm Thanks, Aaron. You are correct. Here is the link to the previous discussion. http://www.designers-guide.org/Forum/YaBB.pl?num=1087411058 As I understand from the link, the capacitance between G and S will be -Csg in BSIM3V3 model. I am going to post a new thread about LNA design procedure that is very confusing. Hope you could help. |
Title: Re: Cgs and Cgs vs Vgs Post by Andrew Beckett on Mar 18th, 2014, 4:21pm See also my response to your identical question http://www.cadence.com/Community/forums/p/28791/1332097.aspx#1332097 - I'm assuming that's you, because it's an enormous coincidence otherwise. Andrew |
Title: Re: Cgs and Cgs vs Vgs Post by baab on Mar 20th, 2014, 12:20am Thanks. yes, it is me. |
